What is that smell?
11K views 5 replies 6 participants last post by  Shrek
#1 ·
Anyone have mold/mildew smell that is strong? Worse after rain. Can’t find anything wet, ever. Pulled the drain from bed cover thinking it might be getting into cab but it hasn’t eliminated smell nor do I think that can get in cab. Have used Ozone, Lysol, shampoo carpet, etc. Funky!!! Any advice? I have full cab, Platinum, full sun roof, no leak found. Changed cabin air filter, need help
#2 ·
Is it after you turn ac or heat on?
#4 ·
Ozium works best by having the truck running, set the air to outside vent, A/C off and the blower at max speed. Spray Ozium into the air intake vents located on the cowling (passenger side) for about 10 seconds. Immediately turn off the engine and let sit over night. Should take care of the mold and mildew inside the evaporator box.
#6 ·
I had a similar issue... My 3rd brake light leaked and soaked my headliner. It made a visible water stain on the headliner.
I bought a product from the WalMarts by Zep called "Air and Fabric Odor eliminator" and sprayed the headliner and the carpet both.
Worked great, I also picked up a bucket of DampRid and put it in the truck for a while to help remove any residual moisture.
