I want to do a lot of off roading in my FX4. What is the best rear gear? 3.73. or 4.10? or stock 3.55? I want to embarrass the Land Rover and Range Rover group that Off roads every month..
Depends on tire size, if you are running 35" or taller id look into 4.88's or taller. If under 35" i think 4.10 or 4.30 if you can find them. Also depends if you tow alot. If you do i would run a short gear. A locker in the front would work better than gears if you just want to impress some snobbie LR folks! ��
I would go 3.73 or higher. I got the 3.73 and in hindsight, I should have gone with the 4.10 just because I read an article that said the gas mileage would have been within 1 mpg of each other. But I am happy with the 3.73.
