1 - 6 of 6 Posts
Figured I needed to join one of these forums before the bug bites me (I see it flying around and closing in on me)
new owner of a lightly used 2018 f150 (stx, sport, 4x4, 2.7)
have goals and dreams of a purely cosmetic end, but I dont want it to come at the expense of too much fuel economy (why I got the tiny engine to begin with)
Welcome. Good luck. You should’ve joined the Prius forum. You’re screwed. [dont say I didn’t warn ya]
I was driving an 09 pathfinder previously, so thats my bench mark for economy. I'm not looking for enduro-mileage, just keep it at around (or slightly above) what I was getting before
Where in FL? I’m in Miami area
You shouldn’t have a problem getting good mileage as far as a truck is concerned with your set up.
this would be my first dabbling into any aftermarket stuff here
first goal of mine, I need to find what width tire/wheel I need to get the wheels flush with the fender, and how much increase in size I can get without lift
other innerwebs sources lead me to believe with stock rims, I could fit up to 275/70r18 without rubbing.... but if I wanted to bring the tires to a width thats flush with the fenders with a wider rim, can I still maintain that same tire height, without a lift/level, and without rubbing?
1 - 6 of 6 Posts
