1 - 20 of 155 Posts
Hoping to get some input from the experts. I have read some threads that call for a brown colored PCV valve as part of a "fuel in oil" TSB that was issued for my year truck. When I look up this part, it does not come up as compatible for my vehicle and I am redirected to the black colored PCV. Does this TSB no longer apply? I think it's #15-0003.
Is this brown PCV different from the black in any way? If I run a catch can does it matter which valve I use? Truck info is in my sig. Thanks!
The brown one is off the 2015+ models and does in fact fit your 2012 Ecoboost.
Call your local dealer and see if they have one in stock, I think I paid a little over $7 dollars for mine from the dealership
Part #[h=1]AA5Z-6A666-D[/h]
Discussion Starter · #4 ·
Yes that's the correct part number. Why haven't parts houses updated their fitments? This seems like a change implemented years ago but they are still pushing the black ones.
2012 F150 Lariat Screw 3.5L
I have the brown one on my 2012. I went to the dealer(part stores didn't have it at that time)and paid $9. I just asked for a 2015 PCV valve and got the brown one
Discussion Starter · #8 ·
From the smaller size of the opening and the change in the design, I would say they tried to get it to evacuate LESS gasses into the intake but over a wider range of intake pressures. The issues on the early models was accumulation of moisture, then a sudden amount of moisture all at once. It appears they were trying to constantly evacuate a lower volume of air, but more often. I wonder if this is a moot point if you're running a catch can. I mean if it goes through the CAN wouldn't I just want a straight pipe there?
I have since installed the brown one per the TSB, but haven't noticed any difference in the amount of junk in the CC, frequency or composition. It's the same as it was before with the black one.
Which brown pcv valve did you take apart? Saw this on tascaparts.com... looks like the part has been superseded again
AA5Z-6A666 replaced with KR3Z-6A666?
@SrpRacing Is the black and brown part themselves the same ID?
Just the metal o ring inside is larger vs smaller? The reason I ask is because I am ordering an extra PCV to completely gut, if the plastic itself is different size, I want the bigger one.
That being said, when i look up 14 and older, it still shows black. 15 and newer is the brown, yet mine came with brown. Anyone remaining stock should order a 15+ IMO.
Correct. The parts are completely interchangeable. The black pcv can be used on 15+ vehicles. The black PCV has a larger ID metal ring and plunger. The brown has a smaller ID and plunger. The black would be the go-to for gutting.
I am talking about the actual body of the PCV. Is there any difference in size? That metal o ring will be pulled out when gutting.
guys, resurrecting this post - still have fuel in my oil, going to change the HPFP o-ring today, and thought i may as well swap out the pcv while im at it. I have a catch can system with check valves and clean side separator and this is my question. On the passenger side, the valve cover connection is a PCV valve (which i run to my can, then from my can connect to the connection in front of the intake manifold) - it has the brown PCV but thought i would still change it out (2014 F150 FX4 ecoboost) as i heard per above that AA5Z-6A666-D is superseded by KR3Z-6A666-A. Thats all fine and dandy, but what about the connection on the driver side valve cover - factory tube goes from it, to the bung right before the inlet to the driver side turbo on the intake pipe - is that connection on the driver side valve cover a PCV as well? Do I need to buy (2) PCV's???
ok only passenger side is the PCV - makes sense as passenger side connects to the high pressure (or has potential to be under high pressure) connection on the intake manifold inlet. Where as the driver side only ever sees suction or normal ambient pressure as it connects just upstream of the turbo inlet (i.e. not pressurized)
1 - 20 of 155 Posts
