Who here has Water/Meth Injection?
1 - 8 of 8 Posts
2016 Ford F-150 XLT 2.7L
Just curious who is actually running a water/meth setup
I was advised against it on these vehicles by a well known, in these parts, tuner. Basically, if you tune for it and it fails then you're air/fuel mixture go &^%*&^% and problems could arise faster than you and the computer(s) can adjust for it.
I had it on another turbo vehicle and while I wouldn't say it was a power adder, it helped with cooling the intake charge even more than just the intercooler.
Is it possible to NOT tune for it, yet benefit from the intake cooling benefits?
In other words, nothing to worry if it fails, but benefit while it is working?
Discussion Starter · #4 ·
Just curious if you don’t mind my asking, who advised against it?
I’ve had Unleashed and MPT say I should do it.
Reactions: Boatwaco
Discussion Starter · #5 ·
I think so, but I’d have a hard time spending 800+$ on a system that doesn’t add any power per se.
Reactions: Boatwaco
A good Intercooler cost as much or more.
It'd be great to have a solution at your fingertips that safely addressed a heat-soaked condition when you most might be negatively affected by it.
NOT pulling timing IS adding power. Technically speaking. :)
2018 2.7l 4x4
I have heard this is an option, and have considered it. I have not had overheating issues while towing, but I don't want to..
I landed on trying ethanol first. Not everyone has access to E85 though.
1 - 8 of 8 Posts
