401 - 406 of 406 Posts
2013 with 165k. Engine wise the throttle body has gone out plus the EBOV and both exhaust manifolds have warped.
2012 platinum 4x4 Couple clicks from 120,000 miles. daily driver.
Babied, no, beaten, ehh,. A bit.
  • I do maintain er' well tho, none of that going off the computer for oil change jazz. 5,000mile max.
For what it's worth:
2014 xlt (manufacture date april 2014), bought CPO Dec. 2016 with almost exactly 30k miles. It has 63800 miles now.
I paid it off about 6 months ago and have considered an upgrade, but I absolutely love my truck and I have a goal of 135k before I upgrade now. I see maintenance with a preventative mindset being significantly beneficial to these motors. It seems to love to stay clean, have fresh oil, and often run it with some gusto.
I've replaced: vacuum pump, spark plugs, cabin air resistor and fan, rear rotors and pads, and did the Pegasus coolant fitting cause it leaked a little.
Since I've had it, added catch cans at 42k miles and I've been religious about changing oil at 4k miles or less. The last 2 oil changes I've done at 25-2700 miles to kinda clean it out, and I think it's helped. I've heard a couple of slight ticks since i've had it, but not the dreaded timing clunking, of cold start/low oil pressure wear, but I try to be good at doing the wide open throttle start-up when it's sat for bit.
If you don't know if this, it's one of the best tricks I've learned. On a cold start when you know oil pressure is at its lowest, hold the throttle to the floor and crank the starter. It cranks and wont start. Apparently ignition and/or fuel is cut off, and you can crank it for 5-10 seconds and build up oil pressure before it fires. My gauge will rise up just a little after a few seconds. When I do this, it starts up like its warm and sounds great. I figure batteries are way cheaper than engine internals and my time without my truck... But on that note, got a Bosch AGM battery about 2 years ago, it still cranks the same now as when I got it.
