1 - 13 of 13 Posts
2021 3.5L EcoBoost F150 XLT 302a High Sport FX4 Offroad w/ Max towing
Hey all!
I am levelling my 2021 F150 with a 2" front levelling kit. Im currently running 265/65r18 (stock rims). I am going up to a 275/65r20 with a 20x10 +10 offset, I was told I shouldn't have any issues. I've now been seeing mixed info if I'm going to run into any problems. Any chance I'm going to rub, etc. Will I have to do any trimming?
Thanks in advance!
You should clear just fine with a 275/60r20. That’s actually the new stock size for 2021. Be sure to post some pictures when you get it all installed!
Discussion Starter · #3 ·
You should clear just fine with a 275/60r20. Be sure to post some pictures when you get it all installed!
I updated my post, put the wrong tire size and put a little bit more info about the wheels! Will is still be ok? And you bet, it is all getting installed on April 12th!
Ive heard you can fit raptor takeoffs(315/70R17) on a stock suspension 2021.
Noted! I’ll update when I have everything installed then!
I think it was American trucks that had a Youtube video with the raptor takeoffs on the 2021. You should be able to find it. They said it rubbed slightly but that is a bigger tire than you are talking about in both diameter and width, and you have the level, so i bet you wont have an issue.
If that is accurate, that is impressive!
The 2021’s come with factory 33’s now. I think the Tremor even has 285/70R17. So they have a little more clearance built in because of that.
Reactions: Dworth
IIRC the new Tremor will come with a P rated 275/70/18 A/T from General Tire.
Maybe. Either way the 2021's are on a 33 now. The trucks with 20's get 275/60R20 vs 275/55R20 from before.
10" rims are too wide for a 275
I agree, the tire is a little on the skinny side for that wide of a wheel IMO. It might end up looking slightly stretched once mounted on the wheel.
Discussion Starter · #13 ·
Sent from
Little late, best pic I have right now. Since this pic I've blacked out the emblems and added tailgate F150 inlays.
Sky Cloud Tire Car Wheel
1 - 13 of 13 Posts
