1 - 4 of 4 Posts
Got 2 six led 4 inch pods off amazon, brand is riorand and so far they are nice and heavy good quality and are super bright when I touch the wires to a small 12v battery. Does anyone have a dumbed down diagram of how to wire the 2 lights together off one switch. Will be mounting behind my grill.
These are the switches I bought image.jpg .
the switch is rated for 16amps. The lights are 18 watts each , what size wire should I run?
Will I need a relay ? If so what kind?
Thanks all anything helps
16 awg should be plenty. Get a 12v relay from autozone, and follow the diagram on the packaging. Be sure to put a fuse inline of your power as well.
The easiest way to go about it is to buy a wiring harness. I got my 2 pods off of Assault LED Lighting and paid an extra $20 dollars for a harness that comes with all the wiring, a resistor, switch, and in-line fuse. I feel that is a pretty cheap option, as my switch is the same as yours but lights up red
1 - 4 of 4 Posts
