21 - 25 of 25 Posts
Did you try my suggestion of accelerating normally and the mashing it to see if the foot feed sending unit was faulty?
Plugs and ignition parts to throttles, cooling, turbo waste-gates and such. What about the simple speed limiter enabled "MyKey" which was available in 2012. The OP description is an accurate description of a speed limiter. Runs quite normal to the set MPH, then does not accelerate any more. KM
  • Wow
Reactions: snakebitten
Ha. That’s a good possibility also. I don’t know how that works but would the previous owner have been driving around in that mode?
The universal POAT and the Prestone Platinum is the same thing as the new Motorcraft.
Ha. That’s a good possibility also. I don’t know how that works but would the OP have been driving around in that mode?
Wouldn't it be something!
21 - 25 of 25 Posts
