I've read several different topics on leveling and 35's but I couldn't get all the answers i need.
To start I have a 2011 Ecoboost 3.5L V6 2wd (I know I should have gotten the 4x4) with factory rims and tires. I want to level my truck and put 35's with new rims. I measured each wheel from the floor to the highest point on the fender and here are the measurements. Front: 35.25" Rear: 37.5". Both front and rear are the same height.
Based on my research I can do both a 2.5" on the front and replace the 1.25" rear stock block with a 1.5" block. This will completely level (in theory) the truck at 37.5". From what I'm reading I don't know how 35's will fit without serious trimming. I know offset and backspacing on the new rims is critical. I guess my biggest concern is the 2wd model has a smaller base then the 4x4.
I found performance accessories now carries a 3" body lift kit for the 3.5L ecoboost. What are your thoughts on leveling the truck to 37.5 then adding the 3" body lift? Does anyone have any feedback about these body lift kits? I know you will need rear wheel liners to account for the gap.
Thanks in advance for your feedback!!!!
