61 - 80 of 2,443 Posts
Discussion starter · #68 ·
Getting much closer to making this all happen. All my gaskets and install hardware showed up today. I'll be placing my order for the Full Race FMIC tomorrow.
The little one had a nice long nap today, so I was able to get the coating done on the passenger side. Just had to wash, hit the paint with a light polish and then apply the coating. Three coats to match the drivers side. I didn't have time to hit the trim, tires or wheel wells with dressing. Still think it came out pretty nice.
Do you use clay bars or just the Nano skin pad with the lubricant stuff? I don't know much about the process but I want to do something similar on mine after seeing yours and rbrowns coatings. I will have to do it myself because there aren't any shops around me that do it.
Discussion starter · #70 ·
I use both, depending on the follow up process I am going to use. It's a very easy process.
This last detail, I used the Nanoskin Mitt first, but looked over the paint really closely before polishing and had to hit a few spot with traditional Clay to make sure I had a clean surface to start with. I find that clay works better for removing tar than the Nanoskin products. Just to give you a guideline, I've only been seriously detailing for the last 8 years or so, before that I just liked to keep stuff clean. I have a lot of good tools and products (easily over $1k in polishers alone). I haven't done the hood, roof, tailgate, grill or bumpers yet. So far it's taken me about 10 hours to get to this point.
If you plan on making an order for some stuff, AutoGeek is a easy place to order from and has anything and everything you could ever want. They also have a very good forum to lurk around and learn techniques as well as things to stay away from.
But, if you just want to pick up some off-the-shelf products, I can recommend some good, easy to use stuff.
I would first ask a few questions of you before pointing you in any real direction though.
1. Do you have a DA polisher, like a Porter Cable 7424XP or will you be doing the work by hand?
2. How do you feel about the condition of your paint now? Can you see swirls or marring in the paint when it's in direct sunlight?
3. Have you used basic product like wax or cleaner wax in the past? How much paint correction or detailing have you done in the past?
4. What's your goal in the end? Do you want to use a coating so it lasts? Do you like to wax your vehicle regularly?
If you want to shoot me a PM, we can also chat over the phone and discuss. Feel free to reply here too, we can just discuss in this thread.
Good post! I'm right there with you with the amount of polishers, DA and other that I've accumulated. It can be overwhelming for many, and I agree autogeek is an outstanding place to start!
Discussion starter · #73 ·
Full Race Intercooler ordered! Really looking forward to getting my hands on it.
I ordered it in black with both a Elbow for the Tial BOV and one for the EBOV. That way, I can run either the EBOV or the Tial (not 100% about -35c operation with the Tial).
Also ordered up a drop-in AEM filter. This order was $2300 CDN to my door, so I just didn't have the $$$ for a CAI or Catch Can. Those will have to wait.
4-6 week lead time for the FMIC, so just get to sit and wait now.
With the wait, I will be getting the Turbos and other bits installed before the FMIC shows up.
Waiting for a dyno date from the performance shop for when we can get the truck strapped on the rollers.
Discussion starter · #75 ·
Huge shout out to Mike and MPT!
Updated perf tune for the truck as it sits today (stock) and a stock tune with the limiter removed loaded onto the X4.
Looking forward to hitting the rollers!
In the meantime, I'll be getting a small non-performance add-on sorted out this weekend. been looking forward to getting it done for about a year or so.
Hoping to also get the rest of the polishing/coating done and get protective film on the rear door sills. Should be a good weekend (long one up here).
Discussion starter · #77 ·
Finally got around to this! Took forever as I started it (routing the main power) last year.
The goal was to have a power point in the bed of the truck. could be for camping, powering a small 12v cooler or just to be able to charge a phone, whatever.
I went with a three pot mount and put in a standard 12v socket, dual 5v USB and voltmeter. I rigged up the the 5v and voltmeter to be only on when I turn on the switch. The 12v is hot all the time.
Power was routed through a Blue Sea 6 circuit fuse box.
Main power is a direct 8ga (fused) run from the power distribution box under the hood.
before install
Man, I hate drilling holes, but I figured worst case scenario that I can just put rubber grommets in the holes.
Holes sprayed with zinc-rich rust converter spray after drilled
Hole drilled in the back of the stake pocket and grommet put in to protect the wiring
Main power run into the Blue Sea box
Box is affixed with 3M two sided tape
Box mounted
Power connected to the main distribution box
Looks pretty good to me and out of the way. Almost OEM, lol.
Switch turned on
Discussion starter · #78 ·
Hit the Dyno today. Mixed results, something wasn't right. I'm not sure if it was the set up of the Dyno or what. Logs sent to Mike for review and then I'll re-group and go from there. Stock numbers seemed OK and within reason (284whp/381wtq), but the tuned numbers were off. Possibly something wrong with how I loaded the tunes (not sure, just a guess) or how the Dyno was calculating RPM. It may be worthwhile to hit a different Dyno, but they seemed to be OK with Grimms Truck.
Still a fun day!
Discussion starter · #80 ·
Found out some of the issue was the Gas. It's just poor quality and can't really run a 93 optimized tune on it. Working with MPT on some revisions.
Other issue was heat soak, IAT2 and ECT temp went way up on the dyno runs. I did some street pulls and the truck didn't get near as hot.
No funds to hit the dyno again till after the turbos and other goodies are on, so it will have to wait. Should have this wrapped up by the end of the month though.
