As the title says, I have a 2016 2.7 with 5500 miles on it. I started noticing a rough idle around 4500 miles. Thought it might just be some bad gas. Filled up several times since then at different gas stations. Rough idle still persists. Changed oil at 5400 miles and the rough idle seemed to get slightly worse. It will be a 30 to 50 rpm drop, and sometimes more. Definitely noticeable from inside the cab. I don't have any lights on the dash. I have a Bluetooth ODB scanner and it's not showing anything although I don't know how reliable those are. I don't know what it could be, or if there's anything I should try before taking it in to the dealership? It definitely does not feel right though.
