@Boatwaco feel free to move this to wherever you feel it should go.
This is for my gen 1 (2013)
Any questions, feel free to ask.
Turbo to back of head:
2x 6an full flow 90° back of head
Line length 15.25"
2x 6an full flow 45° turbo
4x M14x1.5 to 6an. The two that go in the turbo you need to make sure the threads are only 8.5mm in length.
Driver block to turbo:
1x M18x1.5 to 6an for the block.
1x 6an full flow 90° from block
Line length 3.4"
1x 6an full flow 60° from turbo
1x m14x1.5 to 6an for turbo. Make sure threads are only 8.5mm in length that thread into turbo
Passenger block to turbo:
1x m18x1.5 to 6an for the block
1x 6an female to male 90 elbow for behind AC compressor.
1x 6an straight off 90 elbow
Line length 3.65"
1x 6an full flow 90 turbo
Passenger side, attach line that comes from the block to the turbo first and the 90 to the block fitting. That leaves the straight connection to connect and you actually have room. After this is connected, then bolt the turbo to the manifold.
Driver's side there's actually more room, but wait to bolt the turbo to the manifold until after you attach this line.
The block to turbo lines are the biggest pain on both sides. They're also not straight shots, so make sure you get the angles close or your line length will be off
Make sure the turbo to back of head lines dont arch higher than the fitting on the head or you'll have a high spot that will have the potential for an air bubble.
6x m14x1.5 to 6an. 4 of them need 8.5mm of m14x1.5 thread length.
2x m18x1.5 to 6an
4x full flow 90 6an
2x full flow 45 6an
1x full flow 60 6an
1x 90 elbow male to female 6an
1x 6an straight
At least 5' of 6an line.
Proper size orings (whatever comes on the jiffy fittings). Sorry, I didn't measure sizes for this.
1x "custom" wrench
Pictures in no particular order.
Edit to add: The listed line lengths are the actual cut lengths.
Line length 15.25"
Line length 3.4"
Line length 3.65"
2x m18x1.5 to 6an
4x full flow 90 6an
2x full flow 45 6an
1x full flow 60 6an
1x 6an straight
1x "custom" wrench
