2017 F150 3.5 ecoboost, 116000 miles. Cam phasers again. Replaced at 31,000 miles, 72,000 miles (New style phasers, timing chain and guides, water pump). Noise is back at 116,000 miles. would an oil additive help.
Interesting. And I am NOT against the Lucas oil treatment necessarily.Noise at 119000 change to 10w40 w/quart of lucas oil treatment, no more noise...
Someone with the clatter needs to try either of those.Interesting. And I am NOT against the Lucas oil treatment necessarily.
But I'd love to know if just the oil viscosity change might have quieted things down alone?
I don't know how he could?Do not know if its the oil or the Lucas, but happy that they are working together.
I don’t miss my 07 Tacoma. It was not trouble free, 4 rear axle seals in 120K a frame that looked like a piece of interior plywood left out in the rain, the brakes with the 1970’s drum in the rear never felt like they wanted to stop the truck like as not very linear in braking force. One front wheel bearing (they aren’t cheap).I miss my Tacoma. It was an awesome rig and only needed maintenance as well.
I bought a 1995 and it was a beater. But only I ever did was an exhaust manifold. It ran awesome and never failed me .I don’t miss my 07 Tacoma. It was not trouble free, 4 rear axle seals in 120K a frame that looked like a piece of interior plywood left out in the rain, the brakes with the 1970’s drum in the rear never felt like they wanted to stop the truck like as not very linear in braking force. One front wheel bearing (they aren’t cheap).
Do you know if these newer cam phasers will work on a 2014 EB?If you get it fixed and there's a slight chance you might keep it, make sure they install the new design phasers not that same '19 and earlier bad design. This is what you want.
You’re Gen1… likely timing chain stretch. Oil will not solveDo you know if these newer cam phasers will work on a 2014 EB?
I tried a bottle of the Bestline additive and it hasn't made a difference yet.
How dangerous is it to be driving my truck until I get this fixed? I have been driving for some local short trips, but haven't put my camper on or towed my boat.
I have about 120,000 on my truck and want to keep it for at least another 100K.
Thanks
Mike
Yes, they should work. In fact, I believe Ford calls from them now (assuming the dealer doesn't have a bunch of old style in stock). The newer phasers are half the noise problem. But the new design won't like begin acting up because they work properly. But on your 3.5 there is the timing chain that is likely the other part of your problem. But if fixed, you should ask for the phasers that are more likely last.Do you know if these newer cam phasers will work on a 2014 EB?
Thanks
Mike
According to the dealer and the paperwork, these are the parts put in.If you get it fixed and there's a slight chance you might keep it, make sure they install the new design phasers not that same '19 and earlier bad design. This is what you want.
As for danger, I've heard of people driving them for a number of years like that. Just sounds awful. But at some point the engine won't be forgiving and it will act up.
Yes!It seems like it makes sense to replace the water pump at this time. No extra labor charge by the dealer. Just the parts. Does this make sense?
Thanks
Mike
Great idea to replace a wear item at only parts cost.Just dropped the truck off and they verified the phasers they have are the latest version.
Thanks
Mike
Definitely. On my previous '12, I also had a high flow (don't need higher pressure, which means they take a spring out) oil pump as well. It's all right there and is seems more/better oil flow might help down the road with Gen1 3.5s.Just dropped the truck off and they verified the phasers they have are the latest version.
Thanks
Mike
