Downpipe install
12K views 19 replies 11 participants last post by  Rutt3.5
#1 ·
Tomorrow morning I'm installing a solo catless downpipe. I can not find anything on torque specs at the turbos. Is everyone just evenly tightening the crap out of them or what?
#2 ·
Just snug them up, and tighten, if needed. If you over tighten them, you'll drive the studs in further damaging the gasket behind the flange. Those studs are a royal PITA to remove, if the gasket goes.
Reactions: BluBoost
#18 ·
Will you get an exhaust leak if this happens?
#4 ·
German Torque Spec :Guttentight
Reactions: BluBoost
#15 ·
Yup, and no cats.
It just signs out to the Police when you stomp on it.
Reactions: Rutt3.5
#13 ·
If you still have the factory resonator, have that removed and you'll hear the turbo whistle (with rear window rolled down) even with the stock muffler.
A flow-through muffler will increase it further. But it may be loud in WOT.
#10 ·
Yea you need some sort of exhaust if you want those turbos to sing...
Reactions: JimmyD750
#12 ·
They're probably fine unless you have an idiot at a dealership use an impact gun on the nuts. They actually stripped one nut on. A map torch, two nuts, and a lock washer finally took the studs out.
#17 ·
Which solo muffler did you go with? Seems there are 3 different ones. I don't want drone at all and I still want to be able to carry on a conversation on the highway. I don't like loud like I used too. Getting old I guess
