Ok folks. Here is why cam phasers rattle. Proof and best pic I’ve ever posted. This worn “ramp” doesn’t allow locking pin to fully seat when shut down. Therefore upon cold soak, lack of oil pressure from excessive drain back of oil and the phasers not seeing oil pressure fast enough, the pin isn’t under enough force to push in the locking groove, therefore since it is not upon shut down of truck, the phaser clack first a few.
This is good info, we will have timing chain kits out in about 12 weeks.
1- they address the weak primary chain.
2- they address the accessible and unnecessary amount of drain back on **** down and any length of cold soak
3- they address secondary tensioner issue we found (more on that once we have run the engine dyno and confirm what we have already but with data)
4- secondary chains will be addressed and we break them (or have on 4-5 builds (seemed like 1 then bam bam all in a row and all 600 ish plus HP)
5- we will offer stronger cam phasers to not allow the backing plate to wear as seen. Pin is designed for like 2-5 million key cycles hence why plates worn.
6- we will offer cam limiters. 60 deg of movement on intake cams is A LOT and 40-50* deg is more than enough
7- better tensioner (primary) helping harmonics and wear thru tensioner that is actually smooth and doesn’t move in and out so much, hoping to reduce 80% of the oem movement
8- adjustable lockable cam gears will be available for big boys with big things and big sticks (bump sticks that is)
9 billet guide pass side and possible billet guide driver side with e85 comparable guides and wear strips
They are NOT Ethanol safe
