21 - 40 of 84 Posts
Discussion starter · #21 ·
Lol, they're 10 bucks per cover... We're not that expensive :p
$10 bucks here, $20 bucks there. Before ya know it I'm licking my ashy lips looking for my next fix :)
I meant color as in looking at the truck from the front side of it.
This is what I mean that I hate on the 2013 and 2014 with HID's with the stock fogs looking yellow.
(photo thanks to AKmedic)
Right...I know what you mean. To the eye, when standing in front of the truck, the Duallys are pure white and the OEM HIDs look more yellow in comparison...which makes sense as the OEM bulbs are 4300K.
A caveat or two to this photo: the fogs had PIAA Extreme Whites in them...and the LEDs have ballasts and way outshine the distance on the PIAAs. I tried to only use them when it was just me on the road for the same reasons we all hate aftermarket HIDs in the factory halogen housings. I now have a pair of JW Speaker 6146 fogs on order.
Reactions: MCDavis
How did the output of the PIAA compare to the stock halogeens? I was looking at the following and thinking I might just pull the trigger on them:
http://www.amazon.com/dp/B00BZR3O46...t_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3V0VJEODYZN69&coliid=I21UN4AM129G64&psc=1
Discussion starter · #24 ·
The output on the Putco's is a joke. Had them for 3 weeks about this time last year. Not worth the money...almost a purely cosmetic "mod".
Amazon.com: Putco 250010W Optic 360 H10 High Power LED Fog Lamp Bulb - Pack of 2: Automotive
PIAAs were slightly brighter and spread a little farther. As MCDavis said, they are more of an appearance mod then an improvement. The ones that I used are made by RaceSport. I just read that AlaskaMan put a good set from VLEDs on his truck. They are about the same thing, but the VLEDs look like they are a better setup.
Ya I was going to say my white LED's make the snow almost too bright. As Rob said yellow is better for snow as you get less glare coming back.
I know what you are saying though noog on the blue tho, it's better than white. I have blue lenses for snowmobiling and they are a good lense for cutting light in some conditions, but yellow cuts the fog better and shows better definition in the snow itself.
For off road lights a blue filter is best for snow. I used to use a pair of lightforce lights and I played around with the yellow and blue filters and personally preferred the blue filter.
Interesting, like how blue do you guys mean? Around 6000k? 8000k? Or higher? I have had 6000k and hated it.
Mind you it may be how the light is on the snow. I don't mind my diffused rigid on the snow as it doesn't have a bright spot. But my 6000k HID's I had I didn't like.
That was a while ago but if I had to guess I would say 7000K ish on the Lightforce lights. This morning driving to work in this blizzard my Rigid DOT's cut through the snow will almost zero glare. The HID's on my work truck are 6000K and the fogs make them look a little yellow.
Reactions: Vozaday
They're filters/covers for the light. I believe the lightforce HIDs themselves are 5000k. They recommend their blue filters for snow. Yellow for dust/fog. I run the crystal filters normally as I don't drive my Jeep in the winter, those are around the same as my 6000k HIDs, snow blue a bit bluer.
Reactions: Vozaday
i'm going to have to try that out. I'll put a slight blue tint over my fogs and see what it looks like.
I have some blue rigid covers laying around somewhere.....
Of course you do. Bet you don't have snow laying around somewhere... Lol
Lol, no... They came with a used pair of rigids I bought. I was wondering why anybody would want blue... I understand green, red, and yellow, but never had a use for blue.
Discussion starter · #40 ·
Man you guys are killing me with the post count about snap on covers :cool:
OP, can you do the same pictures with your truck facing a wall about 20' back?
I'm curious what the actual pattern looks like.
You ask, I deliver. Took these this morning on the way in, sorry that it wasn't darker. I just had no reason to go out last night without the wife giving me the stink eye.
The beam width is wider than what my iPhone6 could capture from the driver's seat. There is still a foot or two of beam past what the picture shows.
Fogs only:
Fogs and stock HIDs:
21 - 40 of 84 Posts
