2019 Supercrew 3.5 Ecoboost with the 10 speed transmission and 28k miles. I have a shudder that I believe is torque converter or driveline/transmission related. There are several symptoms that I don't know if they're related.
The main shudder is under light acceleration, primarily in 10th gear about 45-47mph, especially if there is a slight incline and you increase the throttle. It'll continue to shudder up to about 55mph. It'll also do it on a slight incline in 7th gear around 30mph almost as noticeably. Primary feedback seems to be through the wheel but I've also ridden in the truck as a passenger and can still easily notice it. Time of year doesn't seem to have any effect and I replaced plugs gapped at .028 also to no avail. I don't believe it is driveshaft related because it stops completely by downshifting or by accelerating more aggressively through these speeds. This is by no means something I would consider violent though, just a light shudder of the entire vehicle. I really don't think it's tire related.
Similar feeling that isn't as easy to replicate is taking off normally from a stoplight I feel a slight shudder like previously described right after one of the gear changes but I can't nail down which one exactly, 6th maybe? Feels like it could be when the torque converter locks up.
The final symptom is not much of an issue now in the summer but when I leave work when the truck has sat cold all day around 10-20 degrees I'll be leaving nice and easy to let everything warm up and it has skipped from 1st to 4th with a very noticeable delay followed by a hard shift into gear (people behind me wondering why I'm not accelerating faster type of thing). This has only happened a few times in the two winters I've owned the truck. When the temperatures are warmer in the 60-70s type thing it has also done a slow hesitation shift after sitting for a few hours but not near as bad. Both of these cases are the first, maybe second time shifting through the gears after startup.
Seems to me all of these things could be torque converter but I don't know for sure. Need warranty work done so I'll likely be heading to the dealer in the next few weeks but looking for some advice ahead of time.
