36 gal tank question
9.2K views 14 replies 9 participants last post by  theasphaltrv'er
#1 ·
I have the max tow package and sticker shows 36 gal. tank. I went to put a little gas in the truck this morning as I only had about 40 miles left in it (right up to E). I put $50 in which gave me about 12.9 gals. The needle however shows I've got a 1/2 tank, but my miles shows I have about 192 miles before E. Confused because 12 gal. should only be 1/3 tank and I swore with a full tank I'd have about 500 miles to E. So at 1/2 tank, miles to E should read about 250 miles. Is the truck that smart that it estimates miles to E based on my driving? What about 12 gal of gas showing 1/2 tank? I was only getting about 13 mpg previously but that was mixed in with some towing so I reset the mpg reading prior to getting gas this morning. Not it's showing 17.9 mpg. Wasn't sure where else to post this.
#5 ·
Thanks guys. Does this somehow affect the fuel gauge as well? Not sure how that would be, but I know I put in no where close to 1/2 tank worth of gas but that's what the needle shows. This isn't my DD and I think I've only filled the tank up maybe twice so far.
#7 ·
In the two trucks I've owned, (last one had a 22 gal tank) I've noticed the half of the gauge from 1/2 to E always seems to fall faster than from full to 1/2. Not sure why, but think it might have to do with the gas sloshing around in the tank a lot more because it's half empty and the sending unit will only react so fast.
Also when going up or down steep grades my fuel level can shift 1/4 or more.
Either way I don't think you have have a problem and I wouldn't worry.
#8 ·
When my 36 gallon tank is empty (according to the gas gauge) it really seems to have 6 gallons left. At E, I can only put in 30 gallons. My uneducated guess is: that is the 6 gallons they want you to keep in to cool the fuel pump. I have yet to test this theory by running it out of gas, thank goodness.
#12 ·
If you restart the truck with the front end higher than the rear when you are almost empty the DTE and amount of fuel will be higher than it was when parked because the fuel pickup is towards the back of the tank.
Reactions: scap99
#15 ·
I've noticed the same thing with our 36 gallon tank. At empty the most I can get in it is the neighborhood of 30 gallons. Unless we're traveling I always only put 50 bucks (13 ish gals) in it when it's empty and it brings it up to a 1/2 tank. The miles to empty is 46 when the chimes goes off.
Reactions: scap99
