21 - 40 of 46 Posts
Personally, now that you have narrowed things down as far as you have, I'd address all those DTC's in Forscan related to communications between various modules on the buss.
For sure I would clear them and then see what returns.
While I wouldn't guarantee it's related, it's starting to feel like it is. Especially the PCM not being able to communicate with other components.
Discussion starter · #24 ·
Well, I found it! Fuse no.31 in the power distribution (engine) fuse/relay box... "Run/Start Relay Power"
Not sure how I overlooked it, but replaced that and its all back to normal. As for the underlying cause, who really knows for sure. I am suspicious of the janky seat heater wiring. I think I will go in and clean that up before winter hits... for now it is unplugged from the tap location where it was getting power.
... tough to focus in that tight spot, I have this disconnected for now from the no.10 pin "relay - ignition"
sloppy wiring... both seat heaters ran off of the single power tap and 10A fuse
Not sure why this wire is tapped into the driver's seat heater wiring between the switch (toggle on front of seat) and the heating element... its just dangling there, had a male spade sticking out that appeared to be previously crimped to a wire??? took it out
Discussion starter · #26 ·
The first sigh of relief was a lack of warnings on the gauge cluster, then you bet I was dancing a jig when she cranked over and started right up!
Its crazy a single blown fuse could wreak such apparent havoc.
I know it has been said before, but this forum is the best community I am involved in online. Bunch a good dudes, the lot of ya!
2014 FX4 Ford ecoboost 3 point five, no crank, no start. Wearing harness to truck husband completely replaced off. Uses have been replaced Fuel pump engages starter engages I have tried everything That you guys have said about other people trucks. I can't figure out why the truck won't start anybody can help me out That you guys have said about other people trucks. I can't figure out why the truck won't start. Anybody can help me out I appreciate it
Is the starter cranking, or is it just verified to be getting 12V to the ignition terminal on the starter, but not cranking?
21 - 40 of 46 Posts
