I'm glad you came across this info. I'm certain you will enjoy the look-under-the-hood, so to speak. And it all starts to make sense after you tie it all together. Takes a couple of thousand miles, but it becomes at-a-glance familiar soon enough.
As for the LV SOC value.......
You will find that PID value is NOT the same traditional SOC that you would declare if you tested the AGM with a voltmeter and then looked it up on a chart.
Example:
Of course that traditional chart is not exact either, nor do they all agree with each other. Here's another:
I think the Ford PID value is a proprietary value that is part of a rather sophisticated battery management strategy and although you can rely on it relatively, I wouldn't consider it as inline with the charts above as you might wish it to be.
I'll explain
I just did a real-time voltage reading on the 12V battery in my Powerboost. This is using a Bluetooth voltage meter attached to the AGM directly. Note the timestamp
So the "undisturbed" voltage is 12.63
About what it was this morning before I went to the office.
So I approached the truck this morning and, as you know, that "wakes up" the truck, and lots of modules, lights, and running boards take a quick toll on the battery. And since the OBD interface is triggered, I can get an immediate look at the voltage drop of the battery.
Dropped from >12.6 to 12.1
Also note that there's a 10amp pull on the battery, AND the High Voltage battery is NOT being tapped yet to supply current to the low voltage side.
I get in and turn on accessory mode. (I do NOT start the truck) (see below)
Immediately the DC/DC converter taps the High Voltage battery for 2.9amps @ 280V and supplies the 12V bus with 57 amps # 13V
Of which 31 amps is surplus, thus charging current. And the truck isn't even "running"!
I then wait a few seconds for all 42 modules to wake up and shake hands, and then press the brake and start the truck.
Voltage from the DC/DC converter now increases to 14.2V. Very similar to a traditional crank driven alternator.
About 45 amps are being consumed by the truck, and 32 are surplus for charging the anemic AGM. (77 amps supplied total)
By the way, it's very rare to see the charging current that high beyond a couple of minutes of the truck in ready mode. Especially once the Ford value for SOC approaches 85%. At that point it will switch to trickle charging at best.
Here's arriving home from the office. About a 50 mile commute for the day. I'm actually surprised it's still supplying >14V from the digital alternator, to be honest. Often it will drop to 12.7-12.9V
