So we know what these trucks are rated at from the factory, however what kind of gas mileage have you been getting in the real world?
If on mobile, click your avatar upper right, then account settings then Your Account, then signature.Can I not fit out a signature on here unless I get the paid version?
14 is exceptionally bad unless you are driving 85 mph or driving up the side of Mt. Everest. On a bad day I'll see 17 when it is near zero and driving into a 20+ mph wind.2014 3.5 supercrew 130,000 miles lucky if i get 14 highway being a good driver. i dont think ct winter gas helps, but overall mpg stinks
Wife’s 5.0 is about the same and way less power.2014 3.5 supercrew 130,000 miles lucky if i get 14 highway being a good driver. i dont think ct winter gas helps, but overall mpg stinks
I got 14mpg last week doing and average of 65mph into a NW wind gusting to 40mph. That was ugly. Averaging 17mpg right now with temperatures well under 0F.14 is exceptionally bad unless you are driving 85 mph or driving up the side of Mt. Everest. On a bad day I'll see 17 when it is near zero and driving into a 20+ mph wind.
any suggestions to improve the mpg. im a very conseritive driver14 is exceptionally bad unless you are driving 85 mph or driving up the side of Mt. Everest. On a bad day I'll see 17 when it is near zero and driving into a 20+ mph wind.
Unfortunately, I think fuel economy is the luck of the draw. Some owners report fuel economy north of 25 mpg.any suggestions to improve the mpg. im a very conseritive driver
Buy a car with a better mpg rating. Cars are usually better mpg than the cinder block shaped trucks.any suggestions to improve the mpg. im a very conseritive driver
Have you checked or changed your plugs or air filter latelyany suggestions to improve the mpg. im a very conseritive driver
That's what I thought from everything I read. I was shifting to lower a lower gear and not letting it bog down but then I just stopped and the mileage went up. This was even before I ran the Red Line cleaner.The "conservative driver" thing I think just does not work well on Ecoboost engines. Too much time lugging around at low RPM just increases the time spent in boost. Don't be afraid to use the +- on the shifter to stay well above idle RPM. KM
You missed the leaf on the bottom left! Yes, green is eco in the standard 3.5. Mixed freeway, highway, stop signs, 5 towns there and 5 back. Pretty crazy what these gen 3's can do. They really stay out of the boost until you want it.Green is Eco mode on a Powerboost.
Is it the same on the standard 3.5?
I ask because at freeway/interstate speed I'm not sure it would be distinguishable from Normal mode.
Regardless, it's amazing what that Gen3 3.5 Ecoboost is capable of.
🙄You missed the leaf on the bottom left!
