Bilstein 5100 for 4wd on a 2wd??
17K views 28 replies 8 participants last post by  tatmana
#1 ·
So I got a great deal on some Bilstein 5100 adjustable front shocks from a friend. They are for a 2013 4wd p# 24-187497. My question is will these work on my 2013 2wd? I currently have a 2" spacer and wanted to remove that and install these. I talked to Bilstein and they claim they won't work but could only say it was the valving that was different. What do all of you Ford F-150 wizards think???
#2 ·
No they won't work. Not sure why but I had to order for 4/4. It has a different part numder also than the 2wd
#3 ·
I'm sure they would work just fine. The front ends both weigh the same. The only difference might be actual spring rates between the 2wd and 4x4.
#13 ·
Aren't the 4x4 trucks like 250 lbs heavier, most of which would be in the front axle?
Sent from my LG-D850 using Tapatalk
#6 ·
Maybe not if you're only changing the shock and not the springs.
#7 ·
It will work just fine for your leveling/lifting needs. One thing to remember is that at its lowest setting, it's already 1" higher than the 2wd variant. If you are not planning on bringing it back to stock 2wd height with these, go for it.
I went the opposite on mine. 2wd Bilsteins on my 4wd. Stock springs and strut mounts. Enjoy the ride.
#9 ·
Thanks for the input. Do you happen to know if my 2wd will take these at max height? I have a 2" spacer I'm removing so I think these would put me at 3" over stock since they are 1" longer already? That would actually be perfect for me but don't know how my FX2 will enjoy it!
#12 ·
The 5100's have grooves that set the spring perch height. The lowest groove on the 4wd 5100 is already 1" higher than a stock 2wd. If you want to maintain the same height as your 2" spacer, then put the clip at the 1" higher groove according to the Bilstein instructions.
#10 ·
You don't have any cv shafts to worry about so you should be fine. Make sure you get an alignment after
#11 ·
In this same dilemma right now. Have a '12 XLT 2WD and got a good deal on 4WD struts. Going to install them in a few weeks and see how it goes. But now I am thinking about setting them at the second setting after hearing they are already 1" higher.
Let me know your results from this - would be interested to hear your feedback.
#14 ·
250 lb isn't going to make a lick of a difference on a shock. That's just like putting an xl fat guy in the front seat.
Reactions: wootman
#19 ·
There aren't spacers on stock 4x4 struts.
#22 ·
Oh okay. But no that is a level kit.
#26 ·
finally got what I wanted. I am now running no spacers, the 4x4 OE Springs, 4x4 5100 set at the number two ring, and swapped to a fabtech upper control arms while I was in there. I ended up with a 7.5" wheel to well gap front to my 7" wheel to well gap rear. The ride is so much better on the 5100 its almost funny. way smoother yet planted.
