281 - 300 of 558 Posts
Discussion starter · #281 ·
I have the stock intake box and tube for 2013 3.5L
2013 F150 XLT 3.5L
SHould be the same parts. The tube going from the intake system/ox to turbo as well? Send me a PM.
Woo, what about buying the closest size line pliers and drilling them to 3/8's?
Yes, that is going to be one of my options I am thinking.
I couldn’t find my nice calipers, so this measurement will be close, but not exact.
Discussion starter · #284 ·
FYI, this tune for 87 is seeing about 13 psi and is making well over 400hp. The waste gate duty cycle is only about 20% lol, barely working!
Very nice to catch up on your thread. That is awesome you are running 13 psi and it feels that good even on 87! This is awesome!
After my break I am back on the forum. There is a lot of new stuff for me to poke around and see!
Discussion starter · #287 ·
Check this out, first time pulling tail lights (to spray fluid film, no rust anywhere) the factory lights say "Harley"
164401
Ohhhhhhhhh
That's nice
My s#!t is about to blow up!!
Here it is gentlemen. They did not show any of my comments or make direct remarks to my comments that I filled in on paper work, I am not sure why?
This is first oil change from factory fill. Change was done @ 800 miles on factory fill on 10/4/2014 and ran till 4/2/2015 @ approximately 3300 miles. This is 2500 miles total and 180 days exactly. Oil life monitor was set to 100% and when I changed it on 4/2 it read 33%. I have under 5 miles trip(s) (short commute, 2-4 times a day depending on day of week), higher idle times (to let warm up a bit in winter) and drive very lightly on gas, letting shifts occur by 2k.
If you read my post, I also run RX catch can. Drainage smells severely of gas always, however oil dip stick remained within hatch marks.
I am only concerned with the fuel level and Silicon level. The other metal wears is due to the engine being new and still getting break in done, IMO. Does this break in period apply to the silicon levels too or is this due to K & N filter? We shall see on next analysis. If it continues to be a worry, I will put factory air filter back in, which I have sitting here in a box and see if it fixes the problem.
I am not sure what their last sentence means, "Please provide missing FLUID PRODUCT NAME to compare data to the correct standards" ? EDIT - This is the product code for Amsoil, the 5-30 in my case is ASL I believe.
Will take recommendation to change fluid earlier. I will change when computer reads 50% and send for sampling again or when I reach 1500 miles on this change.
What's everyone thoughts?
I also do not believe in Ford's recommended 10K oil change schedule. I have a catch can, and it catches about a quart of gunk (gas, oil and water) per 3000 miles which would otherwise have been recycled through the EGR system or coked on the intake valves. The volume is definitely weather related) I just don't believe that the cam phasers, or timing chain get enough lubrication with such diluted oil even with synthetic.
Reactions: Envious
Discussion starter · #292 ·
Which model is it? 2B?
I talked to a rep and gave him all the information. I said I wanted nothing crazy and to tow like stock, 10k lbs. My order card says 265mm 2A and I went with 2800-3000 stall. I asked it not flash above 3000, but I dont know if they followed through, I will ask. It is billet front cover "pro" series but I think that is all they offer for 6r80. Got a small discount on black friday. I also have the saudi trans cooler. Only bought this because I am pulling the trans to check for rear main seal leak, lol. We will see how it helps performance. Will be installing it in the spring.
They said I can still tow with this like stock but would not do it every day. I know @Blown F-150 has one but only 2500 stall to tow more frequently.
Discussion starter · #293 ·
Also that thing is heavy as hell, I have never messed with auto trans so I had no idea. Amazing that thing is spinning right next to our feet.
Discussion starter · #294 ·
@sleipnir SO the email invoice says 2A but the packing slip says 2B. I was ask and update when i hear back.
@sleipnir It is a 2B. The B stator is "little tighter....so it won't flash over 3000rpm"
Very nice! I have the 2b in my truck and I think it'll be perfect for my application. It's a really nice unit from the pictures I've seen. You should be super happy with it
Discussion starter · #297 ·
Have you driven on it though or is it park of the current build?
Part of the current build. I'll know how it drives in a couple weeks or less
