101 - 120 of 558 Posts
Discussion starter · #101 ·
So is the 2wd truck 6r80 the same as the mustang? All new mustangs have 2 piece driveshafts as well and a lot of companies offer 1 piece, so I am surprised you had issues getting yours. Hope this one works for you.
I don't know what the front install is on yours, but the rear pinion flange is just 4 12point 12mm bolts. Torque 76ft lbs.
Discussion starter · #102 · (Edited)
4x4 Tremor is rated curb weight of about 5350.
Here is mine with 1/2 tank of gas, a small tool set inside it and a hitch. My wagner intercooler probably added a little weight too, that thing is heavy as ****. This is with factory spare, jack, wheels etc. A 4 door aluminum truck weighs about the same :(:(:(
I also added the larger OEM transmission cooler. This apparently was installed on Gen1 Raptors that went to the middle East, Saudi Raptors. One night I just did a google search and happen to find a thread on it on the Raptor forum. I also came across our very own @BAD454SS (fellow tremor owner) had already done this! His post was in the towing section though and I never saw it.
Although I got mine slightly cheaper than he did :p
Anyways, here it is. I cut the bottom on the plastic shroud from the stock cooler and put it on this one for extra protection. It still clips on the new one but I put a zip tie around it for safe measure. I filled the cooler up with twice the amount of fluid that came out of the stock one upon assembly. This takes about 20min to do taking your time. You have to trim about 2 inch of rubber hose off. That's it.
454 thread below
https://www.f150ecoboost.net/forum/17-f150-ecoboost-towing/71402-larger-oem-f150-trans-cooler.html
I also added the larger OEM transmission cooler. One night I just did a google search and happen to find a thread on it on the Raptor forum. I also came across our very own @BAD454SS (fellow tremor owner) had already done this! His post was in the towing section though and I never saw it.
454 thread below
Don't feel so bad about your pudgy truck. My buddy bought a 2016 and tried rubbing in "how light it was" we hit the scale and with a full tank of gas it was 5800#'s...
My '16 cc 4x4 scales 5600 with a toolbox, maybe 200 lbs worth of tools in the toolbox, a full tank and me.
Baaaaaaaaaaa
Discussion starter · #106 ·
Then I dropped the transmission pan (not pictured) I cleaned the magnet (it was kinda dirty, mostly from break in material I assume). I filled it while cold to between the A and B hatch marks (cold and hot hatch marks). Have to use a hand pump. I guess you could use a funnel and tube from engine bay if you have a helper. It took about 6.5 quarts, i was told it would take 7.5 (shurg). I used Amsoil of course. Make sure you use a link free rag when cleaning panand magnet. I use fresh microfiber towels. Very important.
I replaced the front diff. fluid. I sucked out as much as I could, which only was about a quart. The front diff is supposed to take 1.75 quarts. I used Amsoil severe gear 75 90. I already have amsoil in rear and transfer case as mentioned in this thread. The stock crap that comes out of the front is yellow! (look at the line, that is a clear line in the pic)
So now, every fluid, besides the coolant, is Amsoil in my truck.
I also pulled the drive shaft and lubed the splines (pictured dry no lube) with amsoil syn grease. I took measurements as well because I plan on ordering a drive shaft. The grease has helped tremendously. I no longer have the slam when stopping and when taking off from a light. However I still have the harmonics at highway speed. I hope the new driveshaft will fix. Use loctite always on the driveshaft bolts!
Finally, I put on PTP Turbo blankets. Pictured is the driver side.
Thanks for all of this!
Discussion starter · #108 ·
This trans cooler does not let the temp go above 195. We shall see how it does in the summer. It would really shine for you guys that tow a lot.
Im thinking trans cooler when I do the new fluid rather than the bigger pan since the trans has a thermostat in it.
Discussion starter · #110 ·
I did not like the companies that make trans pans currently, so i kept my stock one. The benefit is more fluid takes longer to heat up. If you do a lot of towing, it would help but for me a cooler only is enough.
Next time i change my fluid, i will be drilling my stock pan and welding a drain hole in place.
This cooler is 10row....i was looking at the powerstroke (6.0) it has a factory 31 row cooler and aftermarket Mishmoto is 37!
Is the powerstroke a direct bolt on as well? I think the 10 row will help out a lot more than what we have now. But damn a 37 row would be crazy! Definitely would work the trans thermostat lol I bet temps would stay around 190 regardless of what is going on! (Or whatever temp it opens up at) I am just excited to swap out for the Amsoil fluid. Looking at their 0w-40 engine oil as well.
Side question WooBoost, do they have anything compatible for our T-cases? I know there was some talk that they are phasing out the XL-12 T case fluid from ford and recommending using the LV fluid.
EDIT: Found a post from a bit ago. The red fluid is still compatible with XL-12 for transfer cases for us.
Discussion starter · #112 ·
No it is not a direct bolt in.
I am using amsoil transmission fluid red bottle in my t case, it was xl12 comparable. Ford just changed over to saying use LV in the transfer case. This is the same fluid as the transmission. I dont know if ford added anything to their LV to meet transfer case spec or it is the same thing as before. That being said Amsoil Blue is LV, so you would use the same in t case.
The fluid change is not that big of a deal. Ford has change fluid recommendations over the past decade a few times. Your chance of t case failure due to the fluid is very very small. When i go to change transfercase again in a few years, ill put the blue in.
I think I am going to go direct bolt on route with the saudi raptor trans cooler install or the excursion. Just so it looks oem and fits nice lol.
That makes sense about the fluid I wish they would make up their mind though lol. I didn't think it would make a huge difference but rather be safe than sorry. That means I gotta renew my preferred customer sub on amsoil again. I want to do fluids I know it is time for coolant and my diffs as well. And of course it is winter and freezing lol Thanks wooboost! Getting me motivated to work out in this cold
Discussion starter · #114 · (Edited)
Yesterday I installed (with help) parts I ordered on black friday, including Bilstein 5100 shocks and struts and turbosmart BOV. I also installed the MOOG upgraded sway bar bushings and re-installed my 2.5 degree shims.
I will get some pictures later.
Struts, I DID NOT REMOVE THE AXLE NUT. I removed the Upper control arm ball joint, the tie rod end and the top sway bar nut on the end link and the vacuum line from the hub. That's it. On the 2014, this is first year of bottom strut being 2 vertical bolts. These damn things are press fitted in! I just used a big ass pry bar to pop them out from the bottom. The first side it popped out right on my hand. The coil and strut assembly is a lot heavier than imagined, lol. Hand is swollen. I did not test 4x4 yet but will today, should all be good.
Sway bar is the MOOG hard material pieces that were recomneded on here. I greased them with AMSOIL grease before installing. The stock ones were in perfect shape, however MOOG ones are much stiffer.
I am using stock 4x4 setting on front and 2wd shocks in rear because i have my rear lowered on shackle.
For the pinion shims, i was getting some vibration still after installing custom drive shaft (i installed this to test if it would remove vibration that everyone blames on the stock drive shaft, see this thread for pics of it). Going back in time, i installed this 2.5 shims with the shackle drop initially, that was before traction bars. It ended up being too much according to my measurements, so i pulled them out and put 1 degree in. After traction bars, the pinion does not move a lot, so the 1 degree was too little adjustment and i had over 4 degrees of pinion angle (on my measurements), for traction bars you was 2 to 3 max. I believe this is why i had some slight vibrations. Now i installed the 2.5 back in (i did not remeasure, i just went and drove) and the vibration is mostly gone. I ill continue to see if its better. Right now i should have 1 degree on the front and 2.5 degree on the back resting on tires. This is perfect for a traction bar to be equal and opposite under load.
For my BOV, my ebov did not have any tears in it and still works great. I got the turbosmart to prevent this from happening under high boost. I put the the turbosmart with elbow on my Wagner intercooler, it fits fine. 2014 trucks have a nipple right behind the TB for boost reference so I did not use the map spacer. Also, no bracket will work on the BOV, so the only thing holding it in, is it being screwed in. With how much it screws into the intercooler, there should be no problem with it. The bracket is over kill. I put a bag over the open connector wire that went to the ebov and zip tied it to the vacuum line of turbosmart behidn the interrcooler to prevent as much moisture as possible from getting to it. I did not use a tap in wire either, i had my tune updated to turn off the ebov (p0035) and it did not throw a code yet, so the tune must be working. The BOV was set too tight from the box and was not opening on test drive, i turned it almost a full turn looser and it works much better now. Pics to come of vacuum line routing.
Discussion starter · #115 ·
I bought remote start kit from my ford guy. 2 keys, transmitter for 225 bucks. This thing plugs in behind the glove box in 5 mins. I took my keys to my local ford dealer and the cut them for free with provided key. Just put it in machine and it matches it i guess.
1) after key cut, programed both using both original admin keys. You can google how to do this and read owners manual. If you dont do this and just put it in ignition, it gives you "start malfunction" on LCD screen (if you have this).
2) plugged remote start in tonight, it is so easy on these trucks, 1 plug!
3) programmed remote start on forscan
4) programmed remote start options to appear on LCD screen. Go to settings>vehicle> scroll down to remote start.
5) programmed the lane change to be 5 blinks instead of 3 stock.
6) programmed LCD screen to have this cool compass type thing and show letter directions permanently in right hand corner of screen.
I did not do bambi mode. The only other thing I will have interest in doing in future, is putting LED bulbs in read lights and turning option off in forscan so it doesnt hyper flash.
The truck starts and drives so i dont think i messed anything up! Excited for remote start!
Discussion starter · #116 ·
Here's some pictures. Ill snap the BOV this weekend and lines.
The running boards @Boostking were dustless blasted and had hold tight applied to prevent flash rust. I forgot to take a picture of this and also the befores! dangit! Before there was all kinds of bubbling of paint and underside was flaking off and lots of visible rust. The hold tight was a grey finish. There was lots of rust, the metal had lots of small holes/erosion at the end of the board closest to front tires after the blast was done. Line x sanded the hold tight and then coated it. Line X Premium (uv resistant). Did you know you can line X plastic? Its not as strong of a bond line metal but in low use areas you can do it and it will not fail.
The running boards are appearance package (?) metal with plastic end caps and plastic top inserts that snap in. I used a heat gun to heat up the plastic step part so they would not break and pulled them out. I still have them. I decided to leave the plastic off and they covered the holes with "tin tape" and line x over the this and did the end caps separately. It came out really nice except a few of the holes "caved" in like with the line x so there are a few dents on the boards. I spray fluid film inside the running boards. If there was not an opening on the ends beneath the plastic end caps, I would have line x over them entirely but the holes still allow for moisture to enter.
I also put grease fluid film on the metal mounts that the running boards mount too to prevent those from rusting (did take pic, too cold).
The map sensor is from the cold pipe in front of the TB. If you go back a few pages you will see the map sensor from the manifold has a bit of oil on it. This one has zero oil and was pulled a few hundred miles later. :confused:
Compass screen and the direction letters both added in forscan
I like that center console cover. Where did you get that?
Discussion starter · #119 ·
The center leather is from redline goods originally, although an upholstery shop can make it. I picked up on black friday. The foam added under is done by the upholstery shop and wraps on sides, front, back and top. The other pieces are black suede.
I plan on doing my headliner and a few other things in black suede eventually as well.
Discussion starter · #120 ·
Here is how I routed the BOV. As you will see the 14 has factory nipple on intake. No need to use anything at all from the kit except the BOV and line.
The line goes behind the intercooler, behind the air guide shield on drive side, through frame hole into the engine bay and then to nipple.
I didnt get pics of the actual BOV, i will though.
I took the EBOV out of the canister(two bolts) and looked at it, i see no damage and it was still working fine. Then I put it back together and in a bag for storage.
